5.0 advise
Old 08-18-2007, 07:03 PM
woodys5.0
woodys5.0's Avatar
Default 5.0 advise
im building my motor i have a cobra intake 75mm tb 75mm mam 24lb injectors 510 534 lift cam the block is 40 over with the crappy stock heads im just wondering if there is anything else i need to add to it
woodys5.0 is offline
Old 08-18-2007, 07:26 PM
PJB
PJB's Avatar
Default RE: 5.0 advise
Heads and intake and gears would be a start
PJB is offline
Old 08-18-2007, 07:33 PM
backfire2007
backfire2007's Avatar
get a port job and a 3angle valve job. $600 go a long way Imus
backfire2007 is offline
Old 08-18-2007, 07:49 PM
PJB
PJB's Avatar
$600 can buy you a set of used aftermarket heads
PJB is offline
Old 08-18-2007, 08:02 PM
luckythirteen13
luckythirteen13's Avatar
ORIGINAL: PJB
exactly. dont sink a penny in to those stock heads
luckythirteen13 is offline
Old 08-18-2007, 09:07 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
you can find a nice set of aluminum heads for 600.00..I would fly cut the pistonsso a larger cam can be used and/or 1.7 rockers...I would go with a 65 or 70mm T/B you will gain nothing from the 75
ORIGINAL: woodys5.0
2 kwik is offline
Old 08-18-2007, 09:21 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: backfire2007
thats the single WORST piece of advise I have EVER seen on this forum
AdderMk2 is offline
Old 08-18-2007, 10:07 PM
FullAuto
FullAuto's Avatar
What is the TB opening on the Cobra intake?
FullAuto is offline
Old 08-18-2007, 10:47 PM
SoDakStang
SoDakStang's Avatar
ORIGINAL: AdderMk2
I agree. Stock heads are junk. Get a decent set or you are just wasting your money.
SoDakStang is offline
Old 08-19-2007, 12:17 AM
white93pony
white93pony's Avatar
cobra intake has 65mm opening i agree get better heads and better intake i have the bbk ssi and love it gained 10 hp and 12 tq over performer rpm if you cant afford it wait till you can a cam like that with stock heads will run like crap
white93pony is offline
Quick Reply: 5.0 advise
