Am I capable of replacing clutch myself?
#21
RE: Am I capable of replacing clutch myself?
I found for me in a garage with limited room that it was easiest to drop my trans with bellhousing attached. Now, putting it back was a different story. I just took it off since lining up 4 bolts was easier than 6. I did however, install an Astroperformance billet flywheel....what's up with them? Just read where someone said they wouldn't use them again.....
#22
ill never buy from astro again. very unhappy w. a transmission i bought from them.
i still will say it is alot easier to drop the trans then bellhousing...
im doin a trans swap tm or the next night...ill time it... its a quick job... if u kno what ur doin
link to why i wont ****in buy from astro again....
https://mustangforums.com/m_3713624/...tm.htm#3713624
#23
Thanks for all the info, gang.
One quick question about my clutch/tranny:
My ride does have an adjustable clutch. How do I adjust it?
If you want more specs on my car, the guy I bought it from loved it (he had it 15 years) and created this website for it:
http://www.jason.fletcher.net/projec.../82mustang.htm
#25
If it's an adjustable cable, there is a nut on it where it attaches to the clutch fork. You can loosen or tighten to adjust. On a side note, if it is an adjustable, throw it away. They're crap. Get a firewall adjuster, aftermarket quadrant, and a STOCK cable. Works the best IMO. My BBK adjustable cable is crap. Stretched and is fraying.
#27
It's not really an adjustable clutch, you have firewall adjuster that allows you to adjust the clutch cable. To adjust it, you turn it clock-wise or counter-clockwise, you might have small allen bolts that you need to loosen so you can turn it. Adjust it to how you want the pedal to feel.
#28
The ford motorsports adj. cable is a strong cable.
ORIGINAL: lookin4astang
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 11:50 AM
