I thought i had seen it all..
the other day i started my car then i shut it off all of a sudden it would not start from the key inside but i would jump it under the hood and it started fine... then with the key off as im walking towards the back of the car i hear the pump still running.. so im puzzled the keys are in my hands not the ignition so i put the key in turn it a couple times, pull it out the pump is still running, finally i pull the relay on top of the ecm pump is still running so im like ok this is weird i turn the car on pull the relay car dies so im like ok...i put the relay on key off pump is of.. ok i open the key pump turns on turn the key off pump is stays kicking i really dont have any clue on what it can be.... please help
RE: I thought i had seen it all..
your right, but most of the more knowledgeable people here will tell you the same thing.
we are here on our own free will, to try and help other people. if i have to read what should be 3 paragraphs, all jumbled into 1 long sentence, i move on to the next thread.
ORIGINAL: mattdel
You'reright, but most of the more knowledgeable people here will tell you the same thing.
Fixed. [8D]
bradleyb
11-27-2015 07:50 PM
