Compression Results
RE: Compression Results
They are very conisistent, but are low. If this is you daily driver and you NEED this car, or dont really have the money right now if somthing breaks, i would not spray. You could spray and be fine for a while, but you need to decide if you can take that chance.
not with that engine.....I bet there are 100k plus on that engine...it may last for years...months if you slap a nos kit on it..
ORIGINAL: gearbanger
so they are a tad low..... this is my DD... man this kinds sucks.... my goal for 12's by the end of the seaon are not sounding to well[>:]
ORIGINAL: 2 kwik
I would, at this point check and see if someone installed a non-stock camshaft.
Readings like you got could be as a result of some extra duration in there, that will lower the readings of test.......
