17x9's on an 85
Old 08-23-2007, 09:52 PM
black05
black05's Avatar
Default 17x9's on an 85
hey guys, i have an 85 gt that has an svo 5 lug conversion. i have 04 cobra 17x9 wheels with 245/45/17's for the fronts and 275/40/17 for the rear. i know that the rear will fit cause i took the quad shock out and put in the upr extreme duty control arm set. however i just got word that the wheels wont fit in the front??? does anyone know if i will have a problem?i guess the concern is that the 85's have smaller fender wells and the tires will hit or something? i hope this is not true cause i just got the car painted and its coming home soon to be completed. someone please give me some convincing news.....
black05 is offline
Old 08-23-2007, 09:57 PM
primetime5.0
primetime5.0's Avatar
Default RE: 17x9's on an 85
I have those wheels on my car and they only rub on a full lock, did you just swap rotors up front or 94+ spindle swap?
primetime5.0 is offline
Old 08-23-2007, 10:02 PM
88_cobra
88_cobra's Avatar
i have those same wheels. u will be fine in the rear but the front u could have problems. mine is an 88 and i put 91-93 fenders on it to give it wider wheel wells. but since urs is an 85 u will probably have rubbing issues. mine also rub at full lock on the control arms. u could try putting a tubular k member w/ tubular a arms. it could make some space. what year is urs primetime?
88_cobra is offline
Old 08-23-2007, 10:11 PM
black05
black05's Avatar
ORIGINAL: primetime5.0
well, i honestly dont know, i was told by the person that i bought the car from that the 5 lug was done by using svo rotors and calipers. it wont bother me if they rub the wheel well a little cause i can trim it if need be but i cant have it hitting the fender that would be no good the car is just painted and looking beautiful.
black05 is offline
Old 08-23-2007, 11:17 PM
primetime5.0
you'll be fine there you can get rack limiters so it wont rub, but if they just swapped rotors your center cap won't fit on the wheel
Old 08-24-2007, 01:25 AM
raven_ghostwolf
raven_ghostwolf's Avatar
Yes they will rub I have 17x8 sn95 wheels on my 87 with 245/45-17's on SVO/Lincoln hubs, mine use to rub but I fixed it with out using 91 - 93 fenders. Your center caps will also not fit if you do have the SVO/Lincoln front hubs or the Ranger front hubs, once more I had to modify mine even using a 5/16" spacer. You can waste your money on 91 - 93 front fenders but once you put your fender extentions back on you will lose any room you think you just gained.
raven_ghostwolf is offline
Old 08-24-2007, 07:06 AM
black05
black05's Avatar
ORIGINAL: raven_ghostwolf
so were do i put a spacer? behind the studs? should i get washers?
black05 is offline
Old 08-24-2007, 12:51 PM
raven_ghostwolf
ORIGINAL: black05
Washers are the last thing you want to use there, the spacer will not solve the rubbing problem but here is a picture of mine with the spacer in place.
Old 08-24-2007, 04:09 PM
stang8689
stang8689's Avatar
I used rack limiters
stang8689 is offline
Old 08-24-2007, 11:52 PM
capri debris
capri debris's Avatar
I have an '86 with the factory spindles and four lugs. 17x9 Cobra R replicas and the inside lip of the wheel hit the front strut before they were against the hub. I had to buy 1/4" spacers and that gave me about an 1/8" clearance between the inner wheel lip and the strut. Then I had to get longet lug studs because I couldn't get my lug nuts on. The rears fit fine without the quads on, but the car looked funny because the front wheels stuck out farther then the rears. So I got spacers for the rears and longer lug studs and then had room to put my quads back on and the car has a mean stance with no wheel well rubbing issues.
capri debris is offline
JonnyBlazeGT
11-03-2015 01:10 AM
jagbits
11-26-2006 03:48 PM
dlinsc
10-14-2005 06:13 AM
BLU CIVIC
03-04-2005 02:32 PM
instantmassege
02-19-2005 10:19 PM
Quick Reply: 17x9's on an 85
