timing spout connector
Old 08-24-2007, 07:05 PM
92gt50
92gt50's Avatar
Default timing spout connector
how do you guys do your timing when i take the spout connector out it cuts the engine off
92gt50 is offline
Old 08-24-2007, 07:10 PM
HACKGT350
HACKGT350's Avatar
Default RE: timing spout connector
turn your throtle up a little
HACKGT350 is offline
Old 08-24-2007, 07:14 PM
HACKGT350
HACKGT350's Avatar
oh yeah are you sure you arent pulling the dizzy wiring harness? cause that will cut the engine right off. the spout connector is a small little thing that just hangs off the harness to the dizzy
Old 08-24-2007, 07:23 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Make sure it's warmed up also. Turn the car off, pull the spout, start the car.
PRO50SC is offline
Old 08-24-2007, 09:10 PM
nitrous_bob
nitrous_bob's Avatar
i would get your idle set good w/ the iac unplugged first if it's dieing, might have to fix a vac leak b4 you can do it.
reset the puter and do it........i always pull mine out after i start it....then adjust then plug it back in, it lopes at first then smooths out
nitrous_bob is offline
carid
07-08-2016 09:55 AM
mungodrums
10-07-2015 04:01 AM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: timing spout connector
