Junkyard/DIY Performance
Old 02-23-2005, 12:23 AM
  #21
slo93aod
slo93aod's Avatar
Default RE: Junkyard performance
SVO control arms are "tubular"
slo93aod is offline
Old 02-23-2005, 12:25 AM
  #22
fast83gt
fast83gt's Avatar
Probably can't find many in a junkyard though
fast83gt is offline
Old 03-07-2005, 10:49 PM
  #23
rsw007
rsw007's Avatar
taurus fans and mark8 fans and sn95 130amp alts.
rsw007 is offline
Old 03-12-2005, 02:23 AM
  #24
hunterzach_02
hunterzach_02's Avatar
What did the T5 come in besides the 5.0 mustang? just rangers and 4 bangermustangs?
hunterzach_02 is offline
Old 03-12-2005, 05:38 AM
  #25
Demon_Mustang
Demon_Mustang's Avatar
What size rear-ends did Ford trucks use? Because I think F-150's have 3.55 gears.
Demon_Mustang is offline
Old 03-25-2005, 12:50 PM
  #26
tattooedup
tattooedup's Avatar
I know for a cheap five lug conversion that you can use pre-1991 Mark VII front rotors. They mount on real good with the oh so sought after 5x4.5(114.3) Lug Pattern. For the rear you can use two driver side pre 1991 ford ranger axles. They are 28 spline and you will need the 10inch brake drums. BUT why do all this when you can go to JEGS.COM and they have five lug conversion kits for under 400 bones. The whole kit & kaboodle. P.S. anyone know where i can get a 94-95 rearend. debating the whole IRS issue ya know. thanks
tattooedup is offline
Old 04-05-2005, 08:14 PM
  #27
gt03trueblue
gt03trueblue's Avatar
My 82 had a 9", my 87 has an 8.8 but they are both too wide for the stang.
gt03trueblue is offline
Old 04-12-2005, 08:42 PM
  #28
stickstang
stickstang's Avatar
Some Ford trucks were available with traction lock rears. These are 31 spline and they are rebuildable. I have one in my car with Moser axles.
stickstang is offline
Old 04-13-2005, 11:51 AM
  #29
SilverHorse
SilverHorse's Avatar
i found a tech article once, talking about using Ranger axles in the rear, for the 5 lug conversion. You still got drums, but its a cheap 5 lug conversion....
http://www.stangnet.com/tech/lug.html
SilverHorse is offline
Old 04-14-2005, 07:58 PM
  #30
Dearborn5.0
Dearborn5.0's Avatar
There's lots of goodies in that "Official 79-93 5.0L Performance Manual"
by Al Kerchabulm. Its about 40 bucks and talks about GTP heads, and stuff.
Or you can have your local library buy a copy for you
Dearborn5.0 is offline
Quick Reply: Junkyard/DIY Performance
