About to swap out my motor mounts
Old 08-26-2007, 04:46 PM
88natchback
88natchback's Avatar
Default About to swap out my motor mounts
i dont have a cherry picker so i planned to use a jack and a 2x4 to give me enough lift. I have never done this before so if anyone has any inspiring thoughts for me it be appreciated!
P.S., the reason for the swap is a few weeks ago i put on a set of bbk equals and my sterring shaft is rubbing on my driver side header, and my pass is leaning against my strut tower, to you guys think new mounts will remedy this?
88natchback is offline
Old 08-26-2007, 05:17 PM
mnile9127
mnile9127's Avatar
Default RE: About to swap out my motor mounts
I have the same headers. Same problem as you on the pass side.
My s. shaft isnt rubbing. The jack and 2x4 method will work, but
be careful and raise the motor slowly.
mnile9127 is offline
Old 08-26-2007, 07:16 PM
stang8689
stang8689's Avatar
Might need to shim the mount
stang8689 is offline
Old 08-27-2007, 04:04 AM
88natchback
would i shim the part that bolts to the body or the two to the block?
Old 08-27-2007, 05:55 AM
00limited7
00limited7's Avatar
When you jack it up be careful not to crush anything on the firewall with the back of the intake.
00limited7 is offline
Old 08-31-2007, 10:36 PM
aru_next
aru_next's Avatar
jack it up slow on the front of the oil pan, do one side at a time. I just put solid mounts in my 5.0 last week end. good luck
aru_next is offline
Old 08-31-2007, 11:29 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the main thing is only do one side at at time
rmodel65 is offline
Old 08-31-2007, 11:32 PM
SoDakStang
SoDakStang's Avatar
If you have the engine jacked up, it doesn't matter what side you start on. I had the EXACT same problem and new motor mounts will solve this. In fact, I switch to the convertible mounts (they are smaller) and didn't have a problem.
SoDakStang is offline
Old 09-01-2007, 02:07 AM
Alero99
Alero99's Avatar
i ahve this same freaking problem grrrrrrr
i have a cherry picker but im so unsure of what to do once the engine is lifted...
Alero99 is offline
Old 09-01-2007, 09:21 AM
SoDakStang
SoDakStang's Avatar
Take the bolts and nut off and r/r them. Really simple.
Quick Reply: About to swap out my motor mounts
