E303 with the stock rocker arms?? - MustangForums.com
Old 08-26-2007, 07:51 PM   #1
97vette
Default E303 with the stock rocker arms??
will the stock rockers work with the E303? I didn't know if the slot would be long enough. Sure would hate to bend all my pushrods.
97vette is offline   Reply With Quote
Old 08-26-2007, 08:14 PM   #2
stang8689
Default RE: E303 with the stock rocker arms??
Will work fine but i would get some 1.6 roller rockers for extra horse
stang8689 is offline   Reply With Quote
Old 08-26-2007, 09:26 PM   #3
dillon1340
dillon1340's Avatar
shouldn't be a problem. i've got an e303 with stock valvetrain.
dillon1340 is offline   Reply With Quote
Old 08-26-2007, 09:36 PM   #4
97vette
good deal. So what lift can the stock springs and rockers handle?
Old 08-26-2007, 10:15 PM   #5
Joel5.0
Joel5.0's Avatar
Why would you want to install an aftermarket cam, if the suppporting components are not upgraded?.......stock valve springs are so-so for the stock cam, the B, E, stg x, etc.....require valve train upgrades. FYI....with the E303 and 1.6 rockers (stock)....you are .012" from coil bind (.060" is the minimum gap required) on the exhaust valves, add some revs to that condition, and you're close from having valve train problems.....in addition, the spring rate the cam needs to control those valves, is not "available" from the stock parts.......Just a thought.
Joel5.0 is offline   Reply With Quote
Old 08-26-2007, 10:23 PM   #6
97vette
ok will I can get some springs easy enough. I was going to have the heads off anyway . But the rockers will work?
Old 08-26-2007, 10:38 PM   #7
Joel5.0
Joel5.0's Avatar
The rockers will work, but you may also need to change the pushrods....for that, you might need to check the rocker-to-valve gap following the collapsed lifter method......for the direct replacement springs/retainers you may want to ask for them here ..... send him an email and tell him I sent you.
Old 08-26-2007, 10:45 PM   #8
97vette
is checking the rocker to valve for the preload? I'm guessing that is the reason for the differant length pushrods that can be bought.
Old 08-27-2007, 12:59 AM   #9
97vette
what springs are you guys using with this cam if I don't want to run the stockers?
Old 08-27-2007, 01:06 AM   #10
86stanglx
i have the e cam with 1.7 crane rrs and trickflow stock length pushrods. the heads have been milled and the engine runs smooth and quiet well no piston to valve problem
86stanglx is offline   Reply With Quote
Outer shock tower braces guitarman376 Classic Mustangs (Tech) 6 10-11-2015 02:47 AM
1.6 M-6564-B351 pedestal roller rockers uedlose Parts For Sale 1 09-30-2015 09:01 AM
Rear Suspension 2001 GT GimpyHSHS 4.6L (1996-2004 Modular) Mustang 3 09-18-2015 01:27 PM
This weeks build... FivePointToTheOh 2005-2014 Mustangs 0 09-14-2015 04:35 PM
Cam and rear end gear questions Ryan Fitzpatrick New Member Area 3 09-14-2015 03:21 AM
16, 17, 86, arm, buy, cam, clip, e303, mustang, pushrods, rocker, rockers, roller, sound, springs, valve, x303
