Popping through the intake
Old 08-28-2007, 12:21 AM
redmustang83596
redmustang83596's Avatar
Default Popping through the intake
Its just problem after problem with this car. So i finally get the new Trick Flow Track Heat installed, and i take it around tthe block and my heater core explodes on my buddies leg, way cool there. So i bypass the heater core since i dont really care about it. Then i take it around teh block again and then it starts making this god awful noise under acceleration. It sounds like this hollow popping/pinging type of noise. I dont like this noise. I knew my valve lash was a little loose cuz it was making a bit of a clatter, so i pull the valve cover and adjust the lash. Start the car up again and same thing, that nasty *** noise. So i really listen to where the noise is comming from and it definatly sounds like there is popping through the intake. I am thinking maybe an intake valve is staying open or something. I dont really want to pull the heads off, but if i have to, i have too. If any one can help me out with some ideas that would be great. Thanks.
redmustang83596 is offline
Old 08-28-2007, 07:30 AM
samseed101
samseed101's Avatar
Default RE: Popping through the intake
How's your timing? Is the dizzy installed properly or is it off? If you're only hearing or seeing slight problems then it could be off by one tooth. If it's backfiring really bad through the intake then maybe the dizzy is 180 degrees out. Judging by your description, that seems unlikely though.
Does it sound like just one valve or is it pretty consistant with all of them? May be worth checking the timing.
samseed101 is offline
Old 08-28-2007, 07:35 AM
SoDakStang
SoDakStang's Avatar
ORIGINAL: samseed101
I agree. Also, I know you said it is a popping noise, but do your lifters clear your valve covers? That will give you a odd chatter. Might not hurt to run it without a valve cover just to see...
SoDakStang is offline
Old 08-28-2007, 12:13 PM
redmustang83596
The car ran fine, then i drove it for a little bit and thats when it started popping. I know the rockers clear the valve cover, they have worked for 3 years with no problem. I know things like pushrods length are all good, because ive used the same setup for years. The only thing i changed was the intake manifold. I checked the firing order, all the wires go to the correct cylinder. Base timing is set to 12*. I just set the valve lash, but im going to redo that just incase i tightened down the rocker too much. I dont want to pull the heads, so im trying to avoid that. thanks for the help
Old 08-28-2007, 04:03 PM
gspfunk
gspfunk's Avatar
I'm w/ samseed....sounds like your dizzy is off a tooth. I went thru that w/ my 90 LX.
gspfunk is offline
cr620
10-03-2022 10:18 PM
daltron
04-28-2016 08:10 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Popping through the intake
