Maybe I Don't Need To Rebuild The T-5?
Old 08-28-2007, 12:15 PM
Black95MustangGT
Black95MustangGT's Avatar
Default Maybe I Don't Need To Rebuild The T-5?
I'm pretty sure it is the synchros, but i remember awhile back my tailshaft seal was leaking for a long time until i finally got it fixed. Any chance i could be low on transmission fluid that could cause it to grind?
Black95MustangGT is offline
Old 08-28-2007, 12:18 PM
dimebag
dimebag's Avatar
Default RE: Maybe I Don't Need To Rebuild The T-5?
it might have helped cause it yes... but chances are, depending on how long you drove w. low fluid... your syncros are gone... possibly because of the fluid problem
fill that bitch up to where it should be, and test drive it...
dimebag is offline
Old 08-28-2007, 12:34 PM
WhiteWindsor
WhiteWindsor's Avatar
You didn't fill your tranny after you changed the seal knowing it had been leaking for long time?
WhiteWindsor is offline
Old 08-28-2007, 03:55 PM
gspfunk
gspfunk's Avatar
I agree...test it out. You can drive a tranny w/ worn synchros for a long time, you will just have to rev-match it when you shift or let the rpm's drop. I seriously doubt the fluid will fix the issue.
gspfunk is offline
Old 08-28-2007, 05:33 PM
Black95MustangGT
I didn't put the tailshaft seal in, a friend of mine did and i didn't think about it because i really didn't know much then. But he's a good mechanic and probably put it in.
Where in the hell is the place to put more tranny fluid in? I thought you had to take it to a shop to get any kind of service on a manual transmission
Old 08-28-2007, 07:46 PM
WhiteWindsor
It will be on the pass. side of tranny. There is a plug at top and one at bottom. A 3/8 inch ratched will fit. Yes, just the ratchet, nosocket. You will see when you get under there. It would be wise to spend 18-20 bucks for a manual, it will pay for itself 1000 fold.
Pyrate Dave
09-10-2015 07:30 PM
Roush05
09-10-2015 12:23 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Maybe I Don't Need To Rebuild The T-5?
