IAC ?
08-29-2007, 11:46 AM
IAC ?
I have been trying to reset my idle. When i disconnect the IAC module the idle doesn,t change at all ?Anyone know why it would do that?Thanx
08-29-2007, 11:57 AM
in limbo
RE: IAC ?
could be bad. your car acting funny at all?
08-29-2007, 12:05 PM
RE: IAC ?
the idle jumps around sometimes and i cant get my car to idle under 1000rpms.and my gas pedal sticks when u first push it?
08-29-2007, 12:11 PM
RE: IAC ?
The idle droped when i had disconnected it on the old one i had on there.but my idle was weird.So i put another one on there and dissconected it and no change in idle what so ever. So i put the old one back on and still no change in idle at all either.Im stumped.
RE: IAC ?
i have the same problem with my gas pedal. i havent figured out what it is yet.
08-29-2007, 12:20 PM
RE: IAC ?
With the gas pedal hanging, that is probably something to do with the linkage. Clean up around TB and linkage.
08-29-2007, 12:22 PM
in limbo
RE: IAC ?
binding of throttle linkage. or in my case i had this build up around the opening of the TB butterfly cleaned that out and it helped alot, almost clear it up completely.
08-29-2007, 12:23 PM
in limbo
RE: IAC ?
what are you? mass air SD or carbed? i see the year of the car but im just asking
08-29-2007, 12:42 PM
RE: IAC ?
86 gtsd
08-29-2007, 01:26 PM
RE: IAC ?
does 86 have the idle screw on the bottom of the tb that iv been told to never touch?.........did you touch it?
