your opinion on air/fuel ratio guage.
Old 08-29-2007, 12:56 PM
95gtdrop
95gtdrop's Avatar
Default your opinion on air/fuel ratio guage.
are these a bad idea to install?
i have a chance to get a cobalt guage for 15$.
will it work on my 95's o2 sensor?
95gtdrop is offline
Old 08-29-2007, 12:58 PM
samseed101
samseed101's Avatar
Default RE: your opinion on air/fuel ratio guage.
Absolutely 100% useless. It will not tell you your A/F ratio and it will not let you know if you're rich / lean at WOT.
samseed101 is offline
Old 08-29-2007, 01:31 PM
TwotoneVert
TwotoneVert's Avatar
Sams right. A wideband gauge is what you need if you plan to know for sure what you have, or plan to tune by it. A narrow band is just for the pretty light show.
TwotoneVert is offline
Old 08-29-2007, 02:07 PM
bighungrymatt
bighungrymatt's Avatar
why do they even make narrowband a/f gauges haha
bighungrymatt is offline
Old 08-29-2007, 02:14 PM
samseed101
samseed101's Avatar
ORIGINAL: bighungrymatt
For the same reason they make neon lights, fart can exhaust, large spoilers, fake nitrous purge kits, the turbonator, electric superchargers, etc.
Old 08-29-2007, 02:22 PM
bighungrymatt
haha just for show... and another way to make money
Old 08-29-2007, 02:56 PM
95gtdrop
95gtdrop's Avatar
ok scratch that idea.
thanks fellas
95gtdrop is offline
Old 08-29-2007, 07:06 PM
luckythirteen13
luckythirteen13's Avatar
wideband or nothing
luckythirteen13 is offline
Old 08-29-2007, 08:52 PM
94StinkinLincoln
94StinkinLincoln's Avatar
aem wideband guage and sensor, you can see your a/f ratio w/ the guage and hook the tweecer up and see it in there also with ur datalog.
btw sam do you kno how to make the adjustments so that tweecer sees the same a/f ratio as ur wideband, i kno through wire resistance the #'s change. i have the aem guage and it has a bosch sensor.
94StinkinLincoln is offline
Old 08-29-2007, 09:06 PM
mnile9127
mnile9127's Avatar
I'm dealing with the same problem. You have to get a wideband transfer curve for that AEM.
Then load that curve to Cal Con. Good luck trying to find the transfer curve. If you find one
let me know. But open Cal Con , click the setup tab, under the EVP signal transfer click AEM or
PLX thats what I use. then in the second window click AFR.
mnile9127 is offline
Quick Reply: your opinion on air/fuel ratio guage.
