MAF conversion splicing
Old 08-29-2007, 04:11 PM
telsonman
telsonman's Avatar
Default MAF conversion splicing
ok, so i'm doing my MAF conversion this weekend since the fiancee will be at her mom's taking car of her little brother. me and the fox will have some time to ourselves. anyway, from my reading, itseems that they are only 3 wires that i have to splice into. the power and ground from the MAF harness to the EEC connector, and the one going from the fuel pump monitor(under the drivers seat) to the EEC.
is it that easy???
any secrets to soldering these connections??? my buddy who is an electrician said i should buy some clamp that goes on the wire and holds the charge coming from the solder gun so that it doesn't fry the electronics or something. my dad said not to worry about it. i was just planning to soldering the wires then putting electrical tape over it. also, what is the easiest way to get the insulation off without cutting into the wires since i need to strip it off mid-wire???
telsonman is offline
Old 08-29-2007, 08:28 PM
telsonman
telsonman's Avatar
Default RE: MAF conversion splicing
anybody???
Old 08-29-2007, 09:12 PM
88Mach1
88Mach1's Avatar
yeah, it is pretty easy.
check out this page...
http://www.stangnet.com/tech/maf/massairconversion.html
that's what i used when i converted mine. it helped alot. there are some optional connections to make. i don't know if you HAVE to do them, but i did them anyways just to be safe.
they make a wire stripper that removes the insulation midway, but i just used a knife VERY carefully.
as far as the soldering goes, i wouldn't worry about it.
[sm=signs003.gif]
88Mach1 is offline
jwog666
12-27-2021 08:09 PM
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
Colin Ringle
09-15-2015 09:27 PM
Ford_Dude
09-15-2015 03:25 PM
Quick Reply: MAF conversion splicing
