ROUGH IDLE NEED HELP
1993 5.0 306, with anderson heads, cam and intake kit. 30 lbs. injectors, MAC cold air fender kit, 75mm bullet mass air. Having problems getting the car to idle correctly. I have been told to move the mass air position to 1 o'clock or 3 o'clock and it seems to be only a temporary fix. p-lease any suggestions......
Jeff
Jeff
RE: ROUGH IDLE NEED HELP
there is only so many options before it comes down to a tune issue.
TPS, IAC, intake vacuum leaks, fuel delivery problem at low RPM, or the tune.
thats about it.
if i was local to your car, i could have your problem figured out in a half hour, with a multimeter and a can of ether.
thats about it.
Start with the most basic step....gather the data, run a set of DIY KOEO and KOER self-tests.
