Im screwed
Old 08-31-2007, 06:48 PM
65coupe88hatch
65coupe88hatch's Avatar
Default Im screwed
Id gotten home pretty early from work today and decided to do the valve covers for my 86 and when i went to remove the 4 little bolts from the top of the manifold thing (i cant remember the exact name) but one of the bolts were so tight that it snapped the little star bolt right off....Now I cant do anything how would i go about getting it out....?
65coupe88hatch is offline
Old 08-31-2007, 06:53 PM
Mustangkiler
Mustangkiler's Avatar
Default RE: Im screwed
Im guessing your talking about the nameplate on top of the plenum. Only way to get it out would be to drill into it an try and back it out with the drill. But if it broke at least you can get the intake off i had to use a hammer and screwdriver mine were so stripped.
Mustangkiler is offline
Old 08-31-2007, 08:15 PM
p521us
p521us's Avatar
same thing happened to me, i got asmall drillbit and drilled stright down. worked fine for me! good luck!
p521us is offline
Old 08-31-2007, 08:48 PM
daleclough
daleclough's Avatar
+1 for the introduction of a drill....
daleclough is offline
Old 08-31-2007, 09:33 PM
nacanitihs
nacanitihs's Avatar
for the name plate? yea just drill the head off. i only have 2 of the 4 bolts holding mine one. in opposite corners
nacanitihs is offline
Old 08-31-2007, 09:54 PM
jakeachy
jakeachy's Avatar
not as bad as letting jets fall into a carburator manifold...
jakeachy is offline
Old 08-31-2007, 10:10 PM
creekrat
creekrat's Avatar
If you just drill the head off, enough for the plate to slide off, you may be able to grab the nub with a small pair of vice grips and unscrew it that way. It worked for me.
creekrat is offline
jwog666
12-27-2021 08:09 PM
11-18-2015 01:34 PM
breaking
10-02-2015 01:27 PM
09-10-2015 07:23 PM
Quick Reply: Im screwed
