spark plug wires
Old 09-01-2007, 09:45 AM
89bulletlx
89bulletlx's Avatar
Default spark plug wires
how to check spark plug wires?????????
89bulletlx is offline
Old 09-01-2007, 09:47 AM
5.0stanger
5.0stanger's Avatar
Default RE: spark plug wires
Look at them...check for carcks or wear. ALos, you can wet them down at night time and start your car up, if they are bad, you will see spark from them.
If it is a concern, just get new ones, they are that much cash.
5.0stanger is offline
Old 09-01-2007, 09:51 AM
89bulletlx
89bulletlx's Avatar
well i have a new set of msd wires on the car now but the other day it started missing kinda when driveing it kinda bucks plus its feels like its holding back
Old 09-01-2007, 09:55 AM
stang8689
stang8689's Avatar
make sure they are pushed down all the way
stang8689 is offline
Old 09-01-2007, 09:56 AM
5.0stanger
5.0stanger's Avatar
ORIGINAL: stang8689
Yup, and also, how are your plugs, cap and rotor?
Old 09-01-2007, 10:00 AM
89bulletlx
89bulletlx's Avatar
all new plus new blaster coil
Old 09-01-2007, 10:44 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
If the ignition stuff is all new, and you know its installed right, then check for other problems....such as fuel and air, vac leaks....What is your timing set at.
WhiteFoxGT is offline
Old 09-01-2007, 11:03 AM
5.0stanger
5.0stanger's Avatar
What kind of plugs and what are they gapped at? How long after the new parts install did you start having problems?
Old 09-01-2007, 11:06 AM
89bulletlx
89bulletlx's Avatar
motorcraft plugs .54 a week after installed
Old 09-01-2007, 11:11 AM
5.0stanger
5.0stanger's Avatar
Was it just time for an upgrade or whas there are reason for the new parts? Also, I gap mine at .049(guess you gat at .054, not .54) but it shuoldn't make much of a difference. Did you drop any spark plugs when you were installing them? Are they all still tight?
Quick Reply: spark plug wires
