HELP!!! throttle sticking!!!
Old 09-03-2007, 08:44 PM
telsonman
telsonman's Avatar
Default RE: HELP!!! throttle sticking!!!
how did you position the cable to it was directly under there??? how can i wrap the spring???
ORIGINAL: silver91gt
i noticed when I had a PP throttle body it has to have the return spring end right above the idle set screw, i also wraped the spring another turn for more tension
telsonman is offline
Old 09-03-2007, 09:01 PM
AdderMk2
Banned
AdderMk2's Avatar
I actually did the opposite. I removed one of the two springs so that there was LESS tension on my return.... also makes for a lighter pedal
AdderMk2 is offline
Old 09-03-2007, 09:23 PM
silver91gt
silver91gt's Avatar
the throttle cable goes in the same place as stock, i was talking about the spring that holds the throttle blade closed.
if the blade closes too far it will bind sometimes, try to raise the idle a little bit
silver91gt is offline
Old 09-03-2007, 09:48 PM
telsonman
telsonman's Avatar
well i'll try that. it just doesn't make sense why it works with the stock, but with the new one it doesn't.
also, its stiff as hell just to push the pedal/throttle. its almost like it sticks both ways. i'm confused.
Old 09-03-2007, 11:02 PM
telsonman
telsonman's Avatar
any other ideas??? why would it be stiff pushing the throttle too???
Old 09-04-2007, 04:00 PM
telsonman
telsonman's Avatar
i wrapped the return spring one time. still having the same problem. is it possible that the cable could be to long for this or something??? i would figure that everything would stay the same. i'm totally lost on what i can do to fix this problem...
Old 09-04-2007, 10:12 PM
silver91gt
silver91gt's Avatar
are you using the egr spacer too? or just the throttle body on the intake?
Old 09-05-2007, 07:46 AM
telsonman
telsonman's Avatar
i fixed it this morning. yes i have the egr spacer on there.
anyway, it seemed that the ball flange where the throttle cable attached to was positioned more towards the right side of the vehicle(away from the intake). so the cable was sort of flex right there in the cruise control part is(that spring area on the cable). so i attached it normally this morning, and it stuck of course, so i pushed back on the throttle, and pushed the cable towards the intake, and it fixed itself or something. whatever it was, its working now.
another question though...i unplugged the air bypass solenoid, and set my idle at around 700. when i reattached the solenoid connection, my idle shot up to around 1200, and then it took it a couple minutes to work its way down. is this normal???
UrS4
10-03-2015 06:23 AM
BeatnikFink
10-01-2015 08:00 PM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
JDWalton
09-24-2015 08:47 PM
Quick Reply: HELP!!! throttle sticking!!!
