What went wrong
What went wrong
I installed my Taurus 3.8 fan today, I am waiting on my dc controller... I put the fan in, ran the yellow brown to the temporary toggle switch and to a fuse in the fuse box. I ran the ground directly to the negative of thebattery, it ran great for a while but I smelt something on the way home, the spot that I used for the power lead(#10 wire) melted around the whole fuse and totally melted the fuse. I used a 30 amp fuse for the power lead wire, the 15 amp blew when I tried to turn the switch on the first time, thats why I upped the fuse amperage. What needs to be done to correct this issue until I get my controller. Thanks in advance.
RE: What went wrong
It's simple the amperage draw of the fan is greater then the switch or fuse can handle....if memory serves me right the tauras fans originally had a 60 amp maxi fuse that supplied current to the set up......you'll definately need to wire a relay is or get a high amperage rated switch but best bet is a relayprotected by a fuse
RE: What went wrong
If your fan requires a 60 amp circuit, then you may want to size up the wire a little. Maybe an 8 ga. would be better. Also find a heavy duty relay to carry the load of the fan and take the load off the switch. You should be able to find all this at a local auto parts store.
RE: What went wrong
ORIGINAL: FullAuto
You used a 15 amp fuse. It blew. So you put in a 30 amp fuse. Now it blew. Have you considered wrapping it in aluminum foil?
RE: What went wrong
ORIGINAL: CHILLERMAN
RE: What went wrong
ORIGINAL: mjr46
I'd wait to get the fan controller before going any further the tauras fans draw alot of current on initial start up but then levels off once it's spinning.
