idle problems
Old 09-05-2007, 09:26 PM
CHILLERMAN
CHILLERMAN's Avatar
Default idle problems
My problem only exists when the a/c is on. If you approach an intersection and gradually slow down while depressing the clutch. The engine will stall, unless you quickly tap the throttle. Turn the a/c off and the problem goes away. My mods are listed in my signature. I have no other drivability problems, and I have fixed all vacuum leaks. I currently have the idle speed set to 900 rpm and the IAC valve is new. The tps is set to .98 volts. I do not have a scanner yet, so I don't know if I have any codes or not. Other than this the car runs great.
This car was a speed density prior to the mods, but was converted to MAF. Thanks for any help.
CHILLERMAN is offline
Old 09-05-2007, 10:34 PM
Slimboyfatty
Slimboyfatty's Avatar
Default RE: idle problems
did you check the MAF sensor. They can cause idle problems and such. Other than that I have no idea what could be the problem everything I would suggest has already been considered. Try just cleaning off your MAF sensor or replacing it.
Slimboyfatty is offline
Old 09-05-2007, 11:48 PM
ahittz24
ahittz24's Avatar
also the a/c wot relay will cause issues related to this its located in the pass fenderwell under your MAF sensor.
ahittz24 is offline
Old 09-06-2007, 05:59 AM
CHILLERMAN
CHILLERMAN's Avatar
Thanks,
The MAF has already been cleaned to no avail. I will check the WOT relay.
Old 09-06-2007, 08:14 AM
Texas5.0
Texas5.0's Avatar
The two things that I fixed when I was having that problem was the A/C WOT relay and the Vehicle Speed Sensor. It helped a lot but did not completely fix the problem for me becauseI had several intake leaks.
Texas5.0 is offline
2007CalSpec
12-13-2020 11:42 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: idle problems
