Sd cam help!!
RE: Sd cam help!!
full's second choice wins, look at the weak *** range of power in the first one.[:'(]
what about this? will a 112 LSA work with SD stuff? powerband starts 100 lower and ends 100 higher than the "best" offering fullauto listed.
http://store.summitracing.com/partde...p;autoview=sku
RE: Sd cam help!!
ORIGINAL: my77stang
full's second choice wins, look at the weak *** range of power in the first one. [:'(]
http://store.summitracing.com/partde...5&autoview=sku
RE: Sd cam help!!
I have this one in my speed density car: http://store.summitracing.com/partde...p;autoview=sku
It makes good power and power peaks at 5800rpm so it works well with my 4.10's.
Heres my dyno chart with that cam.
[IMG]local://upfiles/8057/35B947C67A6F4333AEF932486D2DDC9A.jpg[/IMG]
RE: Sd cam help!!
ORIGINAL: my77stang
With stock unported heads and intake, you should have a 5200-5400 shift point anyway.
SD needs lots of vacuum. That cam you posted wouldn't idle.
junior04
09-28-2015 10:53 AM
