Nitrous - Common point of detonation?
#21
RE: Nitrous - Common point of detonation?
I'm not staying at a 75 shot, i'm going to quickly move it up to a 150 shot. I want to start with the 75 and move to 100 then the 150. The reason I haven't is because i'm currently on the stock fuel pump! Once that factor is gone I will definately be bumping it up immediately.
I haven't sprayed nitrous ever and don't want to blow up my car the first timeI use nitrous. I am asking you because of your experience with it and was hoping you would set me up with the best answers.
-Jeff
-Jeff
#22
ORIGINAL: nothsa
Thanks, what is your timing set at for the 150 shot? Are you running 93 or race fuel?
-Jeff
ORIGINAL: 1fastzook
Just set the timing anywhere from 10-12deg just to be safe.You should be alright on the same plugs,just get atleast a step cooler soon when your putting in bigger jets.I run a 150shot on a untuned 5.0.
-Jeff
#23
ORIGINAL: 1fastzook
10deg on 93. 1 step colder plug
ORIGINAL: nothsa
-Jeff
ORIGINAL: 1fastzook
-Jeff
-Jeff
#24
ORIGINAL: nothsa
No detonation? .
-Jeff
ORIGINAL: 1fastzook
ORIGINAL: nothsa
-Jeff
ORIGINAL: 1fastzook
-Jeff
-Jeff
jwog666
12-27-2021 08:09 PM
