The best HCI combo for under $1800 ?
Old 09-13-2007, 08:31 AM
  #21
ozz
ozz's Avatar
Default RE: The best HCI combo for under $1800 ?
ORIGINAL: KovacMotorsports
In my opinion a good budget H/C/I setup would be Thumper ported GT40p's with SS valves and a Crane rocker arm stud conversion, Scorpion roller rockers, TFS stage 1 cam, and a good used intake ( i.e. Eddy, Trick flow, Holley, etc.) or a new Typhoon.
i was thinking of doing something similar to above but which crane rocker arm stud conversion kit is the one i need wat are the advantages over pedstal wat setup came stock
ozz is offline
Old 09-13-2007, 08:38 AM
  #22
ozz
ozz's Avatar
also how do i kno wat stud size to get
ozz is offline
Old 09-13-2007, 08:49 AM
  #23
samseed101
samseed101's Avatar
It's not the best combo, but if someone was ever looking for a budget build you can get GT-40 heads, a GT-40 intake, and a decent camshaft for under $500 total
samseed101 is offline
Old 09-13-2007, 06:20 PM
  #24
tooslow5.0
tooslow5.0's Avatar
ORIGINAL: samseed101
im thinking something along the lines of this. where can you find all that for under 500? what cam are you thinking?
tooslow5.0 is offline
Old 09-13-2007, 06:22 PM
  #25
tooslow5.0
tooslow5.0's Avatar
again, can i mill the gt40 heads to regain compression w/o messing with the port and intake bolt alignment? if so, what amount is safe and what c/r should it net me?
Old 09-13-2007, 07:40 PM
  #26
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: tooslow5.0
buy a set of gt-40P heads from www.tristatecylinderhead.com
find an explorer intake used on ebay
find a decent cam. I have a Steeda #19 for sale.... (atleast I will if I ever get it back)
AdderMk2 is offline
Old 09-13-2007, 08:08 PM
  #27
sofob0909
sofob0909's Avatar
[align=left]
[/align]
HOW much power would you see in the gain???
sofob0909 is offline
Old 09-13-2007, 08:11 PM
  #28
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: sofob0909
I had that same basic setup when I was stock... I made 276rwhp
AdderMk2 is offline
Old 09-13-2007, 09:08 PM
  #29
tooslow5.0
tooslow5.0's Avatar
ORIGINAL: AdderMk2
ORIGINAL: sofob0909
276 hp? thats some nice numbers for that setup. was it tuned? what supporting mods did you have?-----side note- for some reason no one has answered my question about milling the heads.[:@]
Old 09-13-2007, 09:22 PM
  #30
AdderMk2
Banned
AdderMk2's Avatar
you can mill the heads, to a certain extent.. how much... i dont know
yes, 276hp... I had a full exhaust, CAI, UDP's, 15° timing, adjustable fuel pressure regulator, and I tuned it with a Tweecer R/T
AdderMk2 is offline
Quick Reply: The best HCI combo for under $1800 ?
