Oh Crap! Intake help!
I want to kick my self for this but stuff hapens. First of all this is about me putting on the water tubes on the lower intake that run to the heater core. Well, my first mistake was not putting it on before boltingthe intakeon. My second mistake was screwing up the top threads on the intake. It is a gt-40 lower aluminum. I know it can be tapped out, butI have no idea what size I would need because I don't own a tap and die set. I tried starting it a few times but it doesn't want to take straight. I tried cleaning the threads up a little but no good. Looks like I may have to pull the intake back off? If I do, will I need to replace the gaskets again? The intake was torqued down. Anyone know the size or a better way about getting this fixed?
RE: Oh Crap! Intake help!
To put the heater tubes on you have to have the intake off. What threads did you screw up? The ones for bolting the upper intake to the lower? You will probably have to get a helicoil kit, which will require a drill and will come with the tap you need.
Yeah, I guess your right. I'll try and get those today. I'm going to Delk Performance which specializes in Mustangs. They should have them. They also have a Dyno. Is there any other sensors that I should change? I have new O2 sensors.
I'd change all 3 sensors just to be sure.. ECT, ACT, and Temp sensor.
As long as you're changing things I'd go ahead and change the PVC screen and install a new PVC if you haven't already done that?
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
