buying 3.73s this friday need advice
RE: buying 3.73s this friday need advice
I'd get the installation kit with all the bearings and seals....to go with the FRPP 3.73s. I went that routr and installed them myself. Also, with FRPP gears you can almost always re-use stock shims. I (carefully) cut the bearing off the stock pinion, and took that shim ot and re-used it. I also re-used the metal spacers on both sides of the carrier. Dont forget 3 quarts of 75-140 and some friction modifier
ORIGINAL: WhiteFoxGT
ORIGINAL: pastang
I JUST HAD A SET OF MOTIVE GEARS PUT IN MINE TODAY. THEY DON'T MAKE A BIT OF NOISE COULDN'T BE HAPPIER. I GOT THE WHOLE SET UP FOR 237.00 SHIPPED
