wont idle after tb install
when i first start my car it wants to die, it wont but it comes very close. i have to rev it a couple times and it will smooth out.
my car did something like this a couple months back. only in the morning on the first start it would die. i re-crank it and its fine.
this is kinda similar cause if its only been a few mins since restart it will idle fine.
all vaccum is good, but i did put a small crack/seem in the tb spacer. that thing isnt too strong. i overtighten the throttle linkage bolts and it cracked it. not all the way thru
RE: wont idle after tb install
mine did that after my long tube install. I pulled out my 02's and DAMN! they were black as hell. So I replaced them and never had a problem since.
But your problem could be alot of things start cleaning all the sensors and stuff first. Like the IAC MAF and TPS
my tps voltage with ign on car off is like .7 something
i cant adjust it or the idle screw cause i dont have tools here
well atleast i figured out how to read the tps, i can adjust it later
thanks guys
thanks guys
