shift light help
shift light help
Ok so I hooked everything up and wired my shift light up. I need help figuring out which # to program in, I assume its 4 but not really sure...the directions are as follows:
* The available ignition pulse settings are .5, 1, 1.5, 2, 2.5, 3, 4, 5 & 6.
PULSE PER REVOLUTION SET (CYL. CALIBRATION) –
Use this feature to calibrate your Digital Pro Shift System to your engine and ignition type. To
enter Pulse Per Revolution Set, press the
MODE (+) button until “PPr” is displayed, then press ENTER to confirm your selection. You may now use the
and “–” buttons to cycle up and down through the pulse settings available on this product. Pulse per revolution settings refer to the number of pulses
or “plug firings” provided by the ignition to the device per engine crank revolution. For example a single coil ignition on a 4-cylinder engine will typically fire
two cylinders per crank revolution. If your ignition matched this type, you would need to set your PPr value to “2” (
* See below). Below is a list of common
