Best Size throttle body and mass air meter
Old 09-12-2007, 04:54 PM
SPE926
SPE926's Avatar
Default Best Size throttle body and mass air meter
Ok I need to know what the best size throttle body and mass air meter to use for my setup. Here is my setup:
Explorer gt40 intake
69 351 windsor heads ( basically the same as gt40's)
1.7 roller rockers
e303 cam
full exhaust (equal length shorty's to offroad h-pipe to flowmaster catback)
underdrive pulleys
smog pump eliminated
I was thinking a 75 mm mass air meter and a 70 mm throttle body but i really don'tknow.
SPE926 is offline
Old 09-12-2007, 05:47 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: Best Size throttle body and mass air meter
more air is not always better......if the velocity slows too much, you'll hurt performance
65 tb and 70 meter is a better choice
nitrous_bob is offline
Old 09-12-2007, 06:04 PM
FullAuto
FullAuto's Avatar
I'd match the TB to the intake opening and run a 75mm PMAS MAF.
FullAuto is offline
Old 09-12-2007, 10:29 PM
SPE926
SPE926's Avatar
So 65 tb and 70 mm then?
SPE926 is offline
Old 09-12-2007, 10:31 PM
jthorn9
The Godfather
jthorn9's Avatar
For your set up, 70mm TB, 80mm MAF (if you can find one).
jthorn9 is offline
Old 09-12-2007, 11:10 PM
91hatchgt
91hatchgt's Avatar
You can buy what ever MAF you want, but 65mm TB would be perfect for your build. 70mm would be overkill unless you plan to upgrade to a stroker or big heads and cam.
91hatchgt is offline
Old 09-13-2007, 12:09 AM
Mustangkiler
Mustangkiler's Avatar
Plus the fact that your intake throttle body opening is only 65mm wide unless you want to shave a lil off go with a 65
Mustangkiler is offline
Old 09-13-2007, 02:14 AM
KovacMotorsports
KovacMotorsports's Avatar
First of all its best to always run a MAF thats larger than your throttle body. As for the sizes...In the real world their's no damn difference between a 65mm and 70mm throttle body on an engine like yours. If you have the ability to open up the manifold to accept a 70mm I would go that route. The reason is that 70mm are the most common and hence cheaper and easier to find but either size will work just fine. As for the MAF size anything from 73 to 80 would work just fine,even a 90mm lightning MAF would work but would require a custom chip.
KovacMotorsports is offline
djbigskrilla
09-20-2022 01:04 AM
1st 4 eyed fox
08-24-2015 06:56 PM
my96mustang
08-24-2015 06:12 AM
Figure8allday
08-22-2015 11:11 AM
stanngg
08-12-2015 03:43 PM
Quick Reply: Best Size throttle body and mass air meter
