bigest stroker w/o boring
Old 09-12-2007, 06:40 PM
tooslow5.0
tooslow5.0's Avatar
Default bigest stroker w/o boring
whats the biggest stroker kit i can get with out boring or any other machine work done? just bolt on basically? how much power should one expect from the various kits on a other wise stock 5.0? i know there is alot of variable involved, so just give me some estimates.
tooslow5.0 is offline
Old 09-12-2007, 06:42 PM
mattdel
mattdel's Avatar
Default RE: bigest stroker w/o boring
none
edit: actually i think i've seen someone slap a 331 kit on a standard 302 bore, and it makes it a 327, but i dont recommend it.
mattdel is offline
Old 09-12-2007, 06:43 PM
88ttops
88ttops's Avatar
342 stroke and with nothing else it will not be worth the gains you will see..
88ttops is offline
AdderMk2
Banned
AdderMk2's Avatar
you need to ATLEAST have the engine honed.... otherwise your just asking for trouble
AdderMk2 is offline
Old 09-12-2007, 06:53 PM
tooslow5.0
tooslow5.0's Avatar
oh yes, it would at least get bottlebrushed (honed). would i gain any hp, or just torque.
Old 09-12-2007, 06:58 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: tooslow5.0
cubes will always add both... but that all depends on what other supporting mods you add
AdderMk2 is offline
Old 09-12-2007, 06:59 PM
luckythirteen13
luckythirteen13's Avatar
i dont know how much it is where you live but here machine work is cheap. boring is ~$10 per cylinder
luckythirteen13 is offline
Old 09-12-2007, 07:42 PM
r.barn
r.barn's Avatar
That would be a 327ci.
stock bore, with no notching of the block like needed with a 347 stroker
r.barn is offline
Old 09-12-2007, 08:25 PM
FullAuto
FullAuto's Avatar
ORIGINAL: r.barn
What he said.
FullAuto is offline
Old 09-12-2007, 08:43 PM
big ben
big ben's Avatar
not sure but i would think with a 347 you might have to clear the rod bolts for the cam i know thats a must on a 383 chevy along with notching the block
big ben is offline
Quick Reply: bigest stroker w/o boring
