Window Fails to Go Up all The way - How to fix
Old 09-14-2007, 05:56 AM
Hawk
Hawk's Avatar
Default Window Fails to Go Up all The way - How to fix
First let me say that I believe this is a technical question, but if not, I apologize to the moderators.
As far as my issue, the drivers side window will no longer go up all the way. The motor pulls the window down no problem and gets it going up generally strong, but then it just stops with about 2 inches of opening. Does anyone know whether this means I need to replace the motor or if there is something else to check first. I appreciate the help.
Hawk is offline
Old 09-14-2007, 06:46 AM
ponyboy302
ponyboy302's Avatar
Default RE: Window Fails to Go Up all The way - How to fix
not to sound like a ***** bag cuz im pretty new here myself and it is a technical question but i believe the 5.0 section is for engine only related tech questions and all other tech questions go in general discussion
ponyboy302 is offline
Old 09-14-2007, 09:44 AM
ZachW04Stang
ZachW04Stang's Avatar
Your gonna have to pull the door panel and look for it binding. Its either the motor is going bad, regulator is bad, or its just binding somewhere.
ORIGINAL: ponyboy302
Nope its for any techinical information
ZachW04Stang is offline
Old 09-14-2007, 10:20 AM
Hawk
Hawk's Avatar
Thanks man, I already have the door panel off, so I will just pull back the plastic sheet and see what I can see.
Hawk is offline
Old 09-17-2007, 06:40 AM
92cobra
92cobra's Avatar
Mine sometimes does this also, the simple fix is just to push on the side of your door as you roll up your window, just start at about half way, and push with your arm a lil bit against the door above the arm rest if you have one, and it will roll right up more then likely. Doesnt take much force i can do it one handed with a broken back, but if your a panzy, stop and use 2 hands heh.
92cobra is offline
Old 09-17-2007, 06:43 AM
Hawk
Hawk's Avatar
Thanks for the input, but I ended up just replacing the motor and I am good to go. Judging from how well the new motor performs, I am going to go ahead and do the passenger side window this coming weekend.
Hawk is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
wraith777
09-28-2015 10:49 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Window Fails to Go Up all The way - How to fix
