N-41 & N-412 cam ?
Old 09-15-2007, 06:08 PM
backfire2007
backfire2007's Avatar
Default RE: N-41 & N-412 cam ?
yeah, I just found that out. why would someone recomend that if thats what I have and just said its a worthless cam, you can run cobras, lightnings, saleens, but you can never beat anyone
backfire2007 is offline
Old 09-15-2007, 07:06 PM
Joel5.0
Joel5.0's Avatar
Even though the cam is the brain of the engine, you need to look at all the components in your combo to ID what mismatch could be causing the lack of performance. The E303 is marketed as a "low cost/emissions friendly/manual or auto trans/performance" cam....and it gives "fair" results provided you go through all the setup required to make it (or any other cam) work.
1. Was your installation degreed?......no?...you don't know if the valves are timed as the cam specs call for....it could be 2-4 degrees advanced or retarded, even if you installed it "dot-to-dot".
2. What valve springs are you using?.....stock or based on the requirements for that cam?....
3. Was the valve train geometry checked and the correct pushrod length installed?
Installing/setting any cam is not a "bolt-on" upgrade, there are other items that affect how the engine performs (or not perform).....BTW...what are you looking for in terms of performance, driveability, use of car, etc?
Just some thoughts.
Joel5.0 is offline
Old 09-15-2007, 07:29 PM
backfire2007
Im looking for something that will pull to 6000-6500rpm range w/ and work well w/ 165afrs. theres gotta be some one out there w/ similar combo.
I got my eye on those anderson cams and I havent heard anyones experience w/ em, bad or good.
and Im not complaining about my E cam, just looking for somethin a little rougher
Old 09-15-2007, 09:28 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: backfire2007
what are the specs on the # 19 cam?
Steeda #19:
.480 lift w/ 1.6 rockers, .510 with 1.7s
220°/226° Duration @ .050
Lobe Seperation: 115°
RPM Range: 2300-6000
OnyxCobra is offline
Old 09-15-2007, 09:58 PM
backfire2007
thanks for the specs on that #19 cam, Ill probably keep my E cam and just get some 165s, because I dont think Ill gain much from a slightly bigger cam. and save some labor $$$$ from switching sticks.
Old 09-15-2007, 10:00 PM
OnyxCobra
OnyxCobra's Avatar
People have made around 330whp with AFR 165s and E303 cam on a 302 so it can work well with the right intake.
Old 09-15-2007, 10:12 PM
backfire2007
thats why I wanna go the 165s route, Im currently running a typhoon intake ported on the bottom side. I just dunno wether to upgrade to a systemax II or just keep this one. Ive got all winter to think about it. I probably wont buy and install my 165s till late winter early spring anyway
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: N-41 & N-412 cam ?
