c4 to aod
c4 to aod
I have a 94 5.0 that has a c4 in it with 3.73 gears which has ****ty gas mileage. I found an aod out of a 90 model that I would lke to put in it. What al would I need on order to do this swap. And whoever put the c4 in this car did not change the ecu to a manual dont know if thats helps ornot but I was just throwing that in there.
[/align]
RE: c4 to aod
it doesn't take much actually.....if you get a good response, contact alternative performace in clinton twp mi
they used to do a bunch of aod to c4 swaps i think it's http://www.alternativeauto.com
RE: c4 to aod
I have been working on getting an AOD setup correct. There is a TV cable that needs to be set just right or you can destory your tranny. It is quiet simple after I called Lokar and a local trany shop. If you go threw with the swap I will give you some great info.
