Roadside issue
Old 09-19-2007, 01:34 PM
DeltaElite121
DeltaElite121's Avatar
Default Roadside issue
Alright, I'm just going to start off with the fact I am still learning about cars, and more specifically I am VERY new to 5.0's.
I just purchased one not long ago, and the engine and transmission are essentially new, and run great. I was heading down to the gas station after cranking it up to make sure everything looks/sounds right to my knowledge, and when coming home we smelled something burning. Seconds afterwards we hear the belt rubbing. Smoke starts pouring out from the hood so we immediately pull over because I really didn't want to risk destroying the car and pissing down alot of money after a rebuild. Turns out the belts got loose and burned a section of it off and snapped.
The battery was also (coveniently) very weak, and nearly dead so we called someone we knew for a jump to see if we could get the car back to my house since it was literally a 1/4th mile away from my house. While trying to crank it, the starter apparently jammed while cranking and we cut one of the power wires to stop it before it fried up the starter, alternator, or something along those lines. It was trying to turn for about 30-45 seconds, which is a considerably long time.
Question is - from the information I have provided, what is the very worst extent of the damage I should expect? I already know I need a new belt. That's a given.The car still easily tried to start after we cut the wire, but I assume I may need another starter. I don't think the engine seized up, because otherwise it probably wouldn't do anything at all.
Can you guys think of anything else I may want to look into? I do know some things and how to pull them off and put them back in and all that since they really aren't hard to do, but I definitely do not want to be ill-minded and do something like blow my engine or tranny considering I just spent alot getting that fixed. Any help would be appreciated as I'm trying to be very careful with this car.
Thanks guys.
DeltaElite121 is offline
Old 09-19-2007, 01:39 PM
PJB
PJB's Avatar
Default RE: Roadside issue
Id check the belt tensioner.
My starter occasionally sticks on. It usually stops once I rev the motor hard enough.
PJB is offline
Old 09-19-2007, 01:45 PM
golden_eye
golden_eye's Avatar
I wouldn't think that there would be any engine damage. You may want to think about replacing the solenoid though. I've had the starter stick on my truck a couple times and aftertapping the solenoid with a hammer it would stop and I'd just restart itwith no problems. That might be harder to do on the 'stang though because of where the solenoid is located (on the starter).
golden_eye is offline
Old 09-19-2007, 01:48 PM
WhiteWindsor
WhiteWindsor's Avatar
Your starter sticking problem is likely the solenoid. Instead of cutting wires, you should have disconnected the batt.
WhiteWindsor is offline
Old 09-19-2007, 02:11 PM
PJB
PJB's Avatar
ORIGINAL: golden_eye
The starter solenoid is mounted to the driver's side inner fender, atleast on fox bodies.
PJB is offline
Old 09-19-2007, 02:21 PM
WhiteWindsor
ORIGINAL: PJB
Yes, on the fox's, i think 94 and up it may have been on the starter;
Old 09-19-2007, 02:49 PM
DeltaElite121
I would have disconnected it, but the connections were on too tight. I didn't have any tools on me at the time, so that wasn't an option. I have plenty of length on the wire still left, so that isn't a problem.
- thanks for the suggestions so far, though. I'll definitely take a look to see if the solenoid is still functioning freely, or if it needs to be replaced or what not.
Old 09-19-2007, 05:14 PM
golden_eye
golden_eye's Avatar
Oh my bad, I'm not quite as familiar with the Fox's as I am with the SN-95's. Yeah the solenoid is definately on the starter in the '94 and up models.
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: Roadside issue
