o2 sensor ? and a bolt ? to do with header install
Old 09-19-2007, 10:18 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: o2 sensor ? and a bolt ? to do with header install
I dont have to worry about removing o2 sensors..... I only run a wideband
AdderMk2 is offline
Old 09-22-2007, 09:24 PM
stoplightnightmare
stoplightnightmare's Avatar
i just rebuilt my whole exhaust and the o2 sensors come off with a plain open ended wrech just make sure to put the wrench as far away from the pipe as posible because the threades nut is welded to the pipe and thats what you o2 sensor screws into
stoplightnightmare is offline
Old 09-22-2007, 09:54 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: samseed101
Hey, I take my O2 sensors fof with a standard open ended wrench. Takes a little more effort, but I can usually replace both sensors in under 5 minutes.
and you have had them out HOW many times???
if they have never been out before, they arent easy to remove... hell, i had to use a pipe wrench to get one loose on my fathers S10
AdderMk2 is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
microgt
08-20-2015 07:12 AM
Valkdriver
5.0L V8 Technical Discussions
08-13-2015 08:57 AM
Quick Reply: o2 sensor ? and a bolt ? to do with header install
