Transmission leaking.....? UPDATED!
So I pulled out of my driveway and i saw a big wet spot......i got under my car and looked and the front right corner or the transmission pan is leaking. Could this just be a gasket or what?
Also this morning on my way to school i pulled out of the drive way in reverse and then put it in drive and it wouldnt go so i was like ****, then i tapped the gas again and it went so i didnt know and i was late for school so i just went on......what could this be?
Oh i have an AOD by the way
RE: Transmission leaking.....?
yea it probably is your gasket. the reason why it didn't go into gear is because u lost transmission fluid and not having it full can cause your tranny to slip. when you give them a little gas they go into gear but that is not good to do. fix that leak and then make sure it is full of tranny flluid
