compression and pump gas
RE: compression and pump gas
Depending on timing 10.5 to 1, ive seen ittried with11 and upbut usually you have to retard so much timing it cancels out the extra compression power or even worse you blow a hole in the piston.
It's gonna depend on camshaft timing as well. A cam with an intake valve that closes later can run more compression than an engine with a cam that closes the intake valve sooner. But yeah, generally around 10.5:1 is a safe maximum in most cases if the tune is correct
I have 11.1, 33* degree's total timing and run 93 octane. My cam is 625/661 lift, dur @ .050 is 246/259 with 112 ls., it is a nitrous grind.The cam and motor also loves race gas, but is steetable with detonation with the 93 and it is not a daily driver but i do cruise with it.
jwog666
12-27-2021 08:09 PM
