why are my interior lights staying on??
Old 09-21-2007, 01:56 PM
five0fm
five0fm's Avatar
Default why are my interior lights staying on??
did anyone have this problem or know wat the fix for it is?
five0fm is offline
Old 09-21-2007, 04:16 PM
jakeachy
jakeachy's Avatar
Default RE: why are my interior lights staying on??
door isnt sitting right?
jakeachy is offline
Old 09-21-2007, 04:31 PM
five0fm
five0fm's Avatar
door is shut fine
five0fm is offline
Old 09-21-2007, 04:33 PM
mattdel
mattdel's Avatar
inside each door jamb you will find a small plunger style button. on the back of it are 2 wires.
jump those 2 wires together with a paperclip or something similar and see if the light goes out.
mattdel is offline
Old 09-21-2007, 08:44 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Have you checked your dimmer switch that also doubles for your interior light switch?
PRO50SC is offline
Old 09-21-2007, 09:04 PM
JohnnyK
JohnnyK's Avatar
Pull out the voltmeter I guess.. Maybe the easiest way is to connect the wires in the door switches (That would make the light switches go ON.. at least in a 67.. It's a plunger, but it makes continuitity when the plunger is out) so you take the door jamb switches out of the equation. Then test the light switch. If that checks out, I guess check each door jamb switch.
JohnnyK is offline
McLeary
03-14-2016 07:50 PM
Colin Ringle
09-15-2015 09:27 PM
MusicCity615
09-12-2015 07:05 AM
v8sn95
09-07-2015 10:17 AM
amandahchase
09-03-2015 10:09 AM
Quick Reply: why are my interior lights staying on??
