Spring Install
Old 09-22-2007, 01:51 PM
86whitepony
86whitepony's Avatar
Default Spring Install
hey guys i have an 1986 5.0 and i cant seem to get these heavy springs to compress enuff to get into place. i tried jacking the control arm up with the spring in place but that didn't work either, i rented an spring compressor from auto zone but it don't compress the spring enough so where i can put it in place. im clueless so please help meeeeeeeeee if you know how to put one in
86whitepony is offline
Old 09-22-2007, 02:34 PM
ACE
ACE's Avatar
Default RE: Spring Install
Are you putting in the Front or Back springs? If your putting in the back you just need to put the body on jackstands and then jack up your rear on the control arm, take off that bolt, then take off your shock and slowly lower your jack and poof, spring is out. FRONT on the other hand is a lil more difficult if you do it this way but can be done.
ACE is offline
Old 09-22-2007, 02:38 PM
86whitepony
im doing the front passenger spring install.
Old 09-22-2007, 08:14 PM
LOUDexhaust
LOUDexhaust's Avatar
Unbolt the a arm, then puts a jack on each side of the a arm to compress the spring and get the bolts back in.
LOUDexhaust is offline
Old 09-22-2007, 10:58 PM
stang8689
stang8689's Avatar
what kind of springs
stang8689 is offline
Old 09-23-2007, 12:51 AM
86whitepony
the stock ones i had to take the whole assembly out because i got into a wreck and busted my strut brace, so i got n.o.s. parts and trying to put the springs back in. i really dont wanna pay 150 for the tow and the other 150 for the labor since they're stock parts. if i i had some eibach's i would want the shop to do that anyways
mtgldr
02-03-2024 09:00 PM
PullTab
10-30-2015 08:46 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Spring Install
