Rear Disk conversion
Old 09-22-2007, 06:30 PM
707FoxBody
707FoxBody's Avatar
Default Rear Disk conversion
Well I found a 95 mustang v6 and grabbed the rotors, and calipers anti-moan brackets, and dust shields. I couldnt grap the rest because I didnt have the tools but when I go back (if its still there) what else should I grab besides the caliper brackets,andbrake lines (rubber and hard lines). Also the master cylinder is still on the car, should I grab that aswell? Thanks.
P.S. Im going to just order new axels because I dont trust the junk hard ones. Which ones would be good to buy?
707FoxBody is offline
Old 09-22-2007, 06:43 PM
raven_ghostwolf
raven_ghostwolf's Avatar
Default RE: Rear Disk conversion
I would get the master and double check what you might need for the parking brakes, that is where I messed up on my conversion and when I went back the car had gone to the crusher had to manufacture my own ends[:@]. Why not use the axles? As long as the car was not hit in the rear and hit the rearend they should be fine for what you will most likely put to them[&:].
raven_ghostwolf is offline
Old 09-23-2007, 01:42 PM
707FoxBody
707FoxBody's Avatar
Yeah It wasnt hit in the back. I guess I could still use them. They just have that speed sensor or what not on them and I wasnt sure if they would still work.
Old 09-24-2007, 01:46 AM
raven_ghostwolf
They will still work that speed sensor stuff is just for the anti-lock brake system since your car isn't equipped with that system it will not effect you at all, my car has those on the front and rear too.
Old 09-24-2007, 06:28 AM
stang8689
stang8689's Avatar
V6 rear is 7.5 not 8.8
stang8689 is offline
Old 09-24-2007, 07:53 AM
raven_ghostwolf
7.5 and 8.8 axles are the same. As for the length they will be a bit longer because they are for the disc brakes, just like the ones I used from the LSC.
11-10-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Rear Disk conversion
