wheel alignment
wheel alignment
what exactly do they use to align the tires. is it somethign i can do myself easily or what? i have lowering spring and the tires are turned in. they are destroying hte inside of my tires. will and alignment be able to fix this. ive herd some say they run lowering springs no problem with an alignment others say i need cc plates
RE: wheel alignment
Ok so you're taking out the lowering springs and putting in drag springs, correct? Regardless, lowering/raising the suspension considerably alters the alignment. I would recommend the plates.
mungodrums
09-28-2015 10:54 PM
