351w iron heads
351w iron heads
so i want to suprise the hell out of my chevy friends with a sleeper engine, i was thinking about building a 347 and using 351 heads and porting them, do you guys know of a good place to go through to have them ported? also how much could a set of ported 351 heads support and would this be a good rought to follow
RE: 351w iron heads
well i was just thinking that since the 351w head flow pretty well, that porting them will make them flow better and since they are iron they will loook stock
RE: 351w iron heads
ya that is the only year head that i hear good things about, but should i just go with a good set of aftermarket heads? i just want everyone to be surprised
RE: 351w iron heads
aftermarket heads be more surprising, when racing. they will cheap better i nthe long run if you can afford them. Especially with a nice build 347. That sounds like a ncie build up man, good luck.
RE: 351w iron heads
thanks for the info and support. would CHS be a good company for the short block? then i was thinking if i do go aluminum heads that i would do a set of Dart pro 1's and get a cam and intake to match, any thoughts on that combo (its going to be kept efi)
RE: 351w iron heads
idealy i am looking for 450hp and similar torque. then i plan on putting a little juice in it in the future. the car will be a weekend warrior/summer toy. Not fully streetable but still driveable
