no spark from coil, but coil is good, help please
Old 09-27-2007, 10:28 AM
Joel5.0
Joel5.0's Avatar
Default RE: no spark from coil, but coil is good, help please
Check the procedure to check the TFI and the PIP sensor .... TFI Module/Hall Sensor Testing Procedure
Joel5.0 is offline
Old 09-27-2007, 10:29 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you just did head gaskets and I assume the car ran before right??? so what did you leave un hooked??? are all the fuses in the fuse box good????
mjr46 is offline
Old 09-27-2007, 10:59 AM
86GT 93LX
86GT 93LX's Avatar
ORIGINAL: mjr46
yeah i was driving and it died on me mjr46 going to get a bone yard dizzy right now
no ho should work right? stinkin lincoln stuff
86GT 93LX is offline
Old 09-27-2007, 11:03 AM
mattdel
mattdel's Avatar
negative on the lincoln dizzy.
you only need to replace the TFI.
mattdel is offline
Old 09-27-2007, 03:26 PM
86GT 93LX
86GT 93LX's Avatar
ORIGINAL: mattdel
both the original coil and dizzy was bad! i bought 2 dizzys just to be safe, less trips to the boneyard. not sure i have the timing where i want it motor is running funny, i suspect a vacum leak or bad iac. did a motor flush, waiting for my friend to come back with a magnetic drain plug. then im putting in full synthetic. hopefully this will help my ignorant actions of porting the heads like a dumas.
Old 09-27-2007, 09:14 PM
86GT 93LX
86GT 93LX's Avatar
why did both my coil and dizzy go out at the same time? im worried something is screwed up that cause it
Old 09-27-2007, 09:21 PM
1fastzook
1fastzook's Avatar
Did you check to see if it has switched 12v to the coil wire
1fastzook is offline
Old 09-27-2007, 09:54 PM
86GT 93LX
86GT 93LX's Avatar
how would that affect it?
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
StalkerGT
09-25-2015 02:41 PM
Mobiusone stang
09-07-2015 08:46 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: no spark from coil, but coil is good, help please
