no spark from coil, but coil is good, help please
Old 09-27-2007, 12:02 AM
86GT 93LX
86GT 93LX's Avatar
Default no spark from coil, but coil is good, help please
ok this car is just giving me hell. i took it out for a dive after doing headgaskets and blew a heater core hose, was able to cut of the end and put it back on. drove a block and car died. no spark, had it towed home, no spark from the coil but the coil isnt bad, i put in a coil i know works and still no spark!! what would cause this??
86GT 93LX is offline
Old 09-27-2007, 12:14 AM
FuzzyDiceRule
FuzzyDiceRule's Avatar
Default RE: no spark from coil, but coil is good, help please
umm, a bad coil, just cause you just put it in doesnt mean its crap
FuzzyDiceRule is offline
Old 09-27-2007, 01:20 AM
86GT 93LX
86GT 93LX's Avatar
i just stuck the coil out of my 86 bronco and it still doesnt spark, and i started the bronco 5 minutes ago so that coil is good. something else is wrong, what might it be?
Old 09-27-2007, 01:36 AM
86GT 93LX
86GT 93LX's Avatar
anyone know if the power to the coil is constant? and where does it come from? the ecu?
Old 09-27-2007, 01:42 AM
86 5.0L
86 5.0L's Avatar
Hmmm i remember I had this problem before (well not ME exactly) dont remember how I fixed it though, it was like 4 years ago[&:] it turned out to be something along the wiring around the coil
86 5.0L is offline
Old 09-27-2007, 02:07 AM
86GT 93LX
86GT 93LX's Avatar
i tried jumping the coil didnt work, not sure why
Old 09-27-2007, 04:58 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
No spark, possibly the ignition module or the pick up coil in the distributor
PRO50SC is offline
Old 09-27-2007, 07:24 AM
tmajikman
tmajikman's Avatar
It could be a bad ground or fusible link, see if you can google a wire diagram for your car and trace the wires.
tmajikman is offline
Old 09-27-2007, 09:36 AM
Gary H
Gary H's Avatar
If you got water everywhere, check the distributor. Dont know if the 86 uses the same horseshoe for the coil, but mine had a wire break in it. Pretty common.
Wiring diagram fig 28 is the one you want
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Gary H is offline
Old 09-27-2007, 10:21 AM
86GT 93LX
86GT 93LX's Avatar
cool, ok theres no spark coming "from" the coil.
if the tvi is bad will that cause an imcomplete circuit to the coil?
if the ecu is bad will that cause the same thing?
Quick Reply: no spark from coil, but coil is good, help please
