headers
headers
hey guys... going to do awhole new exhaust set up.... im probably going to go with 2.5 straight pipes to a set of dynomax super turbos. I alos want to do the headers ... was wondering whats the difference between shorties and long tubes? and whats a good set of hearders to buy and from where... i keep hearing about bbk shorties. what do you guys think?
RE: headers
Shorties are easier to install then Long tubes basically. Shorties are like what you have on the mustang now, they end basically inside the engine compartment and they have bigger primaries and let the car breath. Long tubes exit below your feet with the pipes. Can I ask why you want to run straight pipes to turbo mufflers? Why not try a H pipe or even a X pipe with some better mufflers? The aftermarket makes aboot 3 million possiblities of exhaust for fairly cheap and sound good.
RE: headers
ORIGINAL: ACE
RE: headers
want to run straight pipes because thats whats going to give me the most power... more then x, or h,... and honestly i havent heard any exhaust i really like.. i dont like the flowmasters... .i was thinking maybe bassim.... haha def. spelled it wrong. but never heard them yet.
RE: headers
i would hate to make a new thread about this so i will ask here. for long tube headers, 1-3/4 or 1-5/8? the 1-3/4 are more expensive but do they flow that much better? and i would assume they should fit the same as the 1-5/8 or is it harder to get them in?
thanks
thanks
RE: headers
ORIGINAL: nseoi
thanks
thanks
How will straight pipes give you more power? If you have a pipe going between your exhaust, it will reduce the backpressure and will let your exhaust flow more equally and better then just straight pipes. Look through your summit catalog for mufflers like the Hooker Aero chambers or something because they all dont sound like flowmasters!
RE: headers
ORIGINAL: AdderMk2
um... didnt you ask this yesterday??
https://mustangforums.com/m_3981617/...tm.htm#3981617
Newb, just bump your old threads instead of starting new one for the same content
RE: headers
aight peepz. first of all.. the whole straigh pipe idea giving more power is retarded. straight piping your exhaust is going to give you less power. no backpressure is no good. even supercharged 302's or anything even supercharged you cant put straight pipes and **** like that.even they have to have backpressure. if you want your car to sound good and have good performance exhaust you need to go to mac exhausts website. http://www.macperformance.com/they have all kinds of setups for you car. fomr longtube all the way to the tail pipes.. or short tube. i am going to go with the long tube headers to a non catted h pipe (fitted for the longtubes of couse) to the cat back with chrome tips. mac isnt cheap but it is by far one of the best exhaust companies.
junior04
09-28-2015 10:53 AM
trashxtrash
09-20-2015 10:49 PM
