new pistons - MustangForums.com
Old 10-19-2007, 10:42 AM   #1
GaryBisiniere
Default new pistons
i want to take my 306 apart and put some pistons with alittle more compression in. i have edelbrock performer rpm cyclinder heads with 60cc chambers and 1.90 intake and 1.60 exhaust. what should i get for pistons that i can run atleast 11 to 1 for compression. i want to get the most out of this motor i can on pump gas because next year i want to build a boost motor.
GaryBisiniere is offline   Reply With Quote
Old 10-19-2007, 12:33 PM   #2
hillbilly pony
Default RE: new pistons
I got a set of Speed Pro Forged aluminum's 4.030. had #1 and #5 inthe block and realized #5 rod was bent and just bought a 347 kit. I will let tham go for 100 plus shipping.
hillbilly pony is offline   Reply With Quote
Old 10-19-2007, 12:34 PM   #3
hillbilly pony
Oh. they are flat top w/fly cuts...should be in the neighbor hood for Comp.
Old 10-19-2007, 12:45 PM   #4
67mustang302
What's your compression now? 11:1 is rather high to get away with on pump gas, your tune has to be dead nutz on
67mustang302 is offline   Reply With Quote
Old 10-19-2007, 05:26 PM   #5
GaryBisiniere
whats the compression ratio on those pistons? i have 9 to 1 on the hypertech pistons i got now. and i should be able to run up to 12.5 to 1 on pump gas but thats the limit.....
Old 10-20-2007, 12:22 AM   #6
GaryBisiniere
please email me thanks wsgaaarrryyy@aol.com
Old 10-20-2007, 09:44 AM   #7
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
with 60cc cumbustion chambers you won't get close to 11 to 1 at all on a 302 stroke you'll need a dome piston....I have AFR 185'S with 58 cc chambers and have a .200 kieth black .030 dome pistons........they are awesome and they are not forged but call kieth black they have sprayed up to 400 shots on them with no problem..I'm spraying a 100 shot on them...the special silocon tech they use on them allows for a much more durable piston then the standard cheapy hyperutectic design but with the 58 cc heads it yields me 11 to 1 exactlly and I run pump gas no problem with never any pinging as the aluminum heads will allow you to run such higher compression. I reccommend the .200 dome pistons any day as it'll allow pump gas no prob with aluminim heads and the power gain is definatelly noticable..on a similar set up with flat tops I went 12.79 @105...switching to a slightly bigger cam and these pistons..I went 12.24 @ 111.59
mjr46 is offline   Reply With Quote
Old 10-20-2007, 11:05 AM   #8
my77stang
my77stang's Avatar
you need these.....
they are TRW / Speed-Pro forged .440 dome, they will put you where you need to be.
http://store.summitracing.com/partde...p;autoview=sku
Deck height: 8.206 in. Deck clearance: 0.016 in. Skirt clearance: 0.0050 in. Weight: 572g. Approximate compression ratios: 12.09:1 with 54.5cc, 11.41:1 with 58.2cc, 11.04:1 with 60.4cc, 10.64:1 with 63cc, and 9.83:1 with 69cc head.
i had these with milled 69 351w heads (approx 58cc) and the block was zero decked....... can you say 12:1 snarling beast?
my77stang is offline   Reply With Quote
Old 10-20-2007, 08:49 PM   #9
94StinkinLincoln
94StinkinLincoln's Avatar
i have some JE/SRP pistons -5cc custom psitons, with the exact same heads i have about a 10.5:1 CR
if your interested i might sell them, im thinking of selling the shortblock, if your interested let me know.
94StinkinLincoln is offline   Reply With Quote
WAZZZZUPPP wheres everyone at? uberstang1 4.6L General Discussion 62 04-18-2016 12:20 AM
1968 Mustang Fatback Coyote Restomod poke68 Classic Mustangs (Tech) 21 12-15-2015 07:25 PM
Picked up a 68 coupe, need help on intake/carb selection. uberstang1 Classic Mustangs (Tech) 6 09-20-2015 07:42 PM
New member, need some help. degner122 V6 (1994-2004) Mustangs 2 09-16-2015 08:09 AM
built help EASTIDEE123 5.0L (1979-1995) Mustang 14 09-14-2015 04:52 PM
2249, 331, 440, 50, 60cc, chambers, clearance, dome, ford, hypertech, piston, pistons, probe, skirt, trw
