carb help
carb help
hello well i have a 600 holley on top of my 302 and im not sure if its the carb or if the timing is off or what but whenever i hit the gas like to the floor it stutters...i acts like its going to cut off...and when this happens i let off the gas, but when i roll into it a little it doesnt doe this....whats off? thanks
RE: carb help
you need to properly tune the accelerator pump circuit.....depending on how it is set up...you can change the squirters to larger ones to deliver more fuel on initial accelerator stomps......on most holleys you can change the cams on the accelerator pump circuit to have a steeper ramp to deliver more fuel in shorter time or over a longer period depending on which cam color you choose.....hope this is not all foriegn to you
RE: carb help
http://store.summitracing.com/partde...p;autoview=sku
TRY THIS BOOK.....BUY IT READ IT and put it under your pillow at night and absorb it through osmosis
RE: carb help
That sounds like the accelerator pump circuit
What it does is when you snap the throttle wide open it gives the engine a small shot of gas until the rest of the carb can adjust to the change and not let you notice any hesitation
After you make sure the distributor is in tune and the floats and mixture screws are set that is the next thing i would look at
It sounds like your squirters are to big or the cam is to big
The pump on a 600 is a 30cc I believe the stock pump cam is orange you can buy different cams and squirters to tune it in you know it right when hit the gas and the car responds instantly . When its to small the car has a pause when you hit the gas . When it's to big the car bogs down when you snap the throttle open but then levels out in like a second or so
BTW do not use the black pump cam on a 30cc pump
