C&L 76mm MAF question
89 GT 5-speed, my specs are below the pic, yes not that much i know but its gettin there anyways...im getting a diablo revolution chip and then dyno tuned, but i was thinking of getting a 76mm C&L MAF, how much HP will the MAF give me alone? i know the chip will give like 20 hp or mabye 15,unless someone knows the total?what like 2hp? 3? just wondering. thanks
RE: C&L 76mm MAF question
Don't tune it, you don't need it. When you get H/C/I or a power adder like turbo or s/c then you can start thinking about a tune. Otherwise if you tune it now you are gonna waste the money you spent to have it tuned if you ever decided to add something later on down the road. If you want to have the ability to tune it yourself look into a megasquirt system. It's cheap and effective.
I had my car tuned, and it ran great for the first couple months I was driving it, and I started noticing I was finding more and more driveability problems which I thought they fixed... All they basically did, from what I can tell, wasrichen my A/F ratio and dumped my timing way down low. For the money that I spent on the chip and tune I'm very unhappy, I could have bought a megasquirt and added a wideband 02 sensor and done it myself and known what actually was changed. Also with megasquirt it uses a MAP sensor instead of MAF, so you don't have to buy the $210 76mm C&L setup.
Just some stuff to think about.
I wish I had someone tell me about all this before I started modding on mine. I would have gone with Megasquirt from the get go. I've spent too much money (almost $1500)aon this stupid MAF conversion/meters/tune and am not having the results that I want and shouldhave.
Don't getthe chip you don't need it yet. You can advance the timing yourself without paying for a chip. I'm assuming you are going to do one of those mail order chips? Those really aren't the way to go, every motor reacts different to mods and you aren't going to be happy with it most likely. Buy some lower gears instead, and you'll feel a whole lot faster...
so is that the correct hp range? i heard its about 20hp with the chip alone then like 5hp with the 76mm maf? any ideas? hp to the engine is fine if you know or the wheel whatever. thanks
ORIGINAL: 89TripleWhite
well my timing is already at 12 degrees, what exactly is the diablo chip going to do? i can get it shipped for 200 brand new
jwog666
12-27-2021 08:09 PM
treesloth
09-28-2015 07:03 AM
