water pump compatability (not ford car)
Old 11-05-2007, 02:54 PM
premo
premo's Avatar
Default water pump compatability (not ford car)
here's the deal. i have an 87 nissan 200sx. the 302 and trans is mounted. i have limited space. i had a 95 GT for a parts car but with a bad motor. i buoght a long block for an 88 GT.
so here's my parts list:
88gt long block
front sump oil pan
front sump timing chain cover
edlebrock 4bbl intake mani
mac shorty headers
95 gt stant accessories + brackets
95 gt crank pulley
now, you probably already know the water pump is NOT compatable with the front sump timing chain cover. the only water pumps i could find have hella long shafts and wont work. my question is this, what water pump will bolt onto a front sump timing chain cover but give me a low rise (which is key as i have limited space) that will work w/my 95 GT stang accessories and crank pulley?
thanks in advance
premo is offline
Old 11-05-2007, 03:04 PM
aode08
aode08's Avatar
Default RE: water pump compatability (not ford car)
if no one cant figure it out eventually, go electrical water pump
aode08 is offline
Old 11-05-2007, 05:21 PM
stang8689
stang8689's Avatar
electric
stang8689 is offline
Old 11-05-2007, 08:15 PM
AdderMk2
Banned
AdderMk2's Avatar
+3
i want to run an electric.. but I dont have the $400 for the one I want.
AdderMk2 is offline
Old 11-06-2007, 02:29 AM
premo
premo's Avatar
electric is cool and an option, but im on a budget on this build...
anyone have any ideas???
premo is offline
Old 11-06-2007, 07:52 AM
AdderMk2
Banned
AdderMk2's Avatar
is it absolutely crucial that you use a front sump pan? have you tried fitting a double hump pan in there
AdderMk2 is offline
Old 11-06-2007, 12:15 PM
Gary H
Gary H's Avatar
I think the 94-95 stang has the shortest water pump, but I'm not sure if it will bolt up to the timing cover you have.
Gary H is offline
Old 11-06-2007, 01:44 PM
premo
premo's Avatar
i think i already covered in my initial post that the 94-95 water is NOT hte same......
and yes, its absolutely crucial i use a front sump, otherwise i wouldnt be wasting my time and money.
anyone else?
premo is offline
Old 11-07-2007, 08:31 AM
Gary H
Gary H's Avatar
I know it's not the same. What timing cover are you using? There are several different styles. Or use the SN95 front cover and pump and drill it for a dipstick.
Gary H is offline
Old 11-07-2007, 11:01 AM
premo
premo's Avatar
66-84 car w/front sump. same bolt pattern for the pump as a foxbody 5.0
sn95? you referring to the 95 stang one?? i was actually thinking about doing this but it seems to have disappeared into the blackhole that is my garage lol
premo is offline
Quick Reply: water pump compatability (not ford car)
