idle problems
Old 11-18-2007, 03:30 PM
Red FIVE O
Red FIVE O's Avatar
Default idle problems
the search func officially blows, it turns up no results.
in the mornings after it turns on it sounds like a cam(really lopey) but its not. its all stock
before it would take afew seconds then even out and idle normal. but yesterday morn it took nearly 3 or 4 minutes and didnt and died twice.
ive set out to clean:
iac
the pcv
check the tps
and need info on how to go about cleaning these components and if theres anything else i nned to look for let me know
info on my car 87 5.0 SD, no recent mods
thanks everyone.
Red FIVE O is offline
Old 04-25-2008, 10:36 PM
vmpetrone
vmpetrone's Avatar
Default RE: idle problems
You can start by cleaning the throttle body with carb cleaner. Just remove the rubber air intake until you can get to the throttle body with a can of cleaner. You should also remove the IAC valve and spray it out good. Just make sure you have a new gasket or dont damage the old one. Try one thing at a time though so you know what the problem actually was.
vmpetrone is offline
Old 04-26-2008, 12:25 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
look for vaccum leaks
mjr46 is offline
2007CalSpec
12-13-2020 11:42 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: idle problems
