1995 mustang 5.0 shake violently
Old 03-06-2014, 05:41 PM
fastfarmer
fastfarmer's Avatar
Exclamation 1995 mustang 5.0 shake violently
my 1995 5.0 Gt HO runs rough and shake violently from idle to 1500 rpm, I have replaced mass air flow sensor and idle sensor the timing is good and the engine mounts and harmonic balancer are good. it acted this way before but stopped before I could find the problem. Has anyone had this problems?
fastfarmer is offline
Old 03-06-2014, 07:48 PM
mongolchuck
mongolchuck's Avatar
Sounds like a miss in more than one cylinder. Since it comes and goes check ignition and fuel for each cylinder. Check for loose grounds and wires.
mongolchuck is offline
Old 03-07-2014, 01:35 PM
fastfarmer
fastfarmer's Avatar
Default still shaking
I replaced all the fuel injectors, checked all ground wires, ignition and fuel to all cylinders they are all good, I put all new wire, sparkplugs, cap and rotor. I double check the timing too. reset the computer and it sill shake badly.
Old 03-07-2014, 04:58 PM
mongolchuck
Is there any noise with it?
Old 03-08-2014, 07:23 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
do a compression test now
mjr46 is offline
Urambo Tauro
12-17-2016 03:30 PM
Urambo Tauro
09-07-2015 12:47 PM
05slpGT
08-12-2015 02:32 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1995 mustang 5.0 shake violently
